Re: 1957 Evinrude starting problem
For those who may not have an ohm meter, I offer this little test circuit.<br />This can be built in 5 minutes using common parts from Radio Shack. The parts shouldn't cost more than $5.00.<br /><br />
<br /><br />Parts list:<br /><br />1- Red LED - 2 volt version<br />1- 9 volt battery clip<br />1- 9 volt battery<br />1- 330 ohm resistor 1/8 or 1/4 watt version<br />2- Alligator clips- one for the points connection, the other for the ground connection.<br /><br />Construction is easy using 20 or 22 gauge wire. Ideally, solder all connections, but twisting the wires and tapeing will work too. Just make sure the connections are good and well insulated. Test the circuit by touching the 'points wire' to the 'ground wire', the LED should light. If not, re-check your work. BTW, the LED has a flat side on it base (where the 2 wires exit the LED). The wire that is closest to the flat side goes to battery negative. If you reverse the LED connections, you won't burn out the LED, it just won't light. Be sure to use the resistor as shown. Without this resistor, the LED will self destruct. The resistor limits the battery current and it's value has been calculated for a 9 volt battery. <br /><br />After building the test circuit, and making the connections (points and ground) , position the LED near the armature plate alignment mark. As the flywheel is rotated, you'll see exactly when the points go open, the LED will go out. I find this easier than having to glance back and forth between an ohm meter and the flywheel alignment marks. <br /><br />While A DVM is an invaluable tool, this is not rocket science. A simple test circuit like the one here can do the job just fine, and you'll save a few bucks to boot.
