1957 Johnson 18hp help
zino
How do you increase the tension on the twist tiller, I have to hold the tiller tension, if I release it for a second, it drops down.
steelespike
I believe it is setup like that so it goes to idle if your not holding it. There is a possibility the coil armatures are dragging on the flywheel.
There should be a taper friction piece way up inside the twist grip handle.-------------Or perhaps the flywheel is rubbing on the coils and that will result in what you have .
