gfinch1050
Thread starter- Joined
- Aug 9, 2011
- 16
I have a 1957 Johnson 18hp, FD-11. It was not running with I got it. ! I guy I got it from said one of the coils overheated. I removed the flywheel and the coils look good but needed to be lined up, did that, set points. New carb kit got it running. Put a new LU seal kit in, fix that. I run it a few time and it did good, but would not go all the way to WOT. On a scale of 1 to 10, 10 being WOT it would go to 9. No biggie adjust linkage on restore. Cleaned sand blasted painted put back together. Test run well but at WOT after a few minutes it would cut out, pump the primer in the fuel line and it would take off. Come home and checked my conversion to a single fuel line system. Cleaned the carb again. OK went out today and it started right up idle good, started to increase the gas a little and it started to cut out like it was only hitting on one cyl. Then it would take off. I going to replace the coils in the morning and see what happen.
Any idles any one. HELP!!!
THANKS
THANKS
