oldfarmall
- Joined
- Jun 18, 2009
- 66
Hello-
I picked up a 1957 Johnson 35HP model RDE-19 for $75.00. Motor runs great, really moves my 14ft boat! Anyway, I pulled the lower unit off yesterday to install a new water pump impeller, housing, and plate. 2 of the 3 screws holding the pump in place came out, the third snapped off, so I have to fix that. My question is, when I pulled water pump, parts of the aluminum casting under the water pump plate were bowed out and cracked, and the water pump plate was warped. I attached 2 pictures of the casing. The problem areas are right above casting number under water pump and the upper left area that looks bowed in towards driveshaft hole. Also, found that this lower unit appears to be from a 1956 or 1955 Johnson, as the pinion gear and bearing do not look like the ones in my 1957 parts book. The casting number is 375769 for the lower unit. Can anyone verify years that used 375769 lower units, I am guessing 1955-1956 by looking at parts books, but the numbers are not the same. Will anything be affected by using this casing as is, or is the casting junk? Also, the bronze bushing below the water pump driveshaft seal appears to have spun in the lower unit casting, as it came out by hand, I thought these were press fit. If I have to look for another lower unit, what years are compatible? 1957-1958 only? I also read that the pinion gear in the older 1955-56 lower units were a weak point, and they beefed it up in 1957. Let me know your thoughts on this lower unit. Thanks in advance for any thoughts!
