1957 Johnson fuel conversion
kazek
Hi.i have 7.5 hp motor that I would like to convert to today's one hose fuel supply.i have read few posts already.what size of fitting should I use for bypass cover,is the size makes difference in the flow?.cover looks bit thin,so is there a special plate to be made to hold the nipple.i decided to go with Kawasaki fuel pump.Any help will be appreciated
HighTrim
Re: 1957 Johnson fuel conversion
The plate looks thin but holds the barb fine. Same sized barb as fuel line used, I personally use 3/16 ID"
kazek
hi.i like the plate conversion ,but dropped the idea after thinking that it may change combution pressure.any thoughts on that?thanks
64osby
Combustion pressure is in the cylinder. It will not be effected. The block pressure will be running your pump. Piston up less pressure, piston down more pressure.
I converted a 10hp Johnson using
the nipple on the manifold, the check valve was removed and one side plugged. So far it has worked great. I used the Mikuni pump.
HighTrim
Nothing to worry about.
kazek
Thanks for replies,intell given was use full.i have done a hole in the bypass cover.looks neat.all a have to do now is use JB weld on it.i am off to make a mounting bracket and before I start drilling I want to know if there is relation on how long is pulse hose and went hole location
HighTrim
Ok Im confused, thought you were using an aftermarket pump?
nwcove
jmo, but jb weld isnt needed , and if any of it breaks off inside the bypass cover, your conversion will be for nothing, as it will destroy your powerhead. ( just did the conversion on a 7.5 with a b&s pump, four pulls on the cord for a motor that sat for years, and it runs every bit as good as a new one, half a pull after it ran....no jb weld required.)
kazek
I am talking about a little brass filter/exaust/went on Briggs pump(got that one because guy had it in stock).as to not putting JB weld...is there enough tread to hold the nipple in place?i dont want it to shoot out or anything like that
HighTrim
You do not need anything, there is enough to tap.
kazek
thanks guys.pump works.i end up using jb on the outside cause i could hear air suckinh in.used bigger (1/4 inch)fitting.anyway engine runs now,bit rough but its new treads topic.thanks again for guidenence
