Huntingducks117
Thread starter- Joined
- Jun 10, 2008
- 8
Well, I got my "new" motor running last night. I changed the lower unit lube, changed the spark plugs, cleaned the gas tank and tried to clean everything up on the the motor. I just ran it in nuetral in a trash can. It ran pretty good, but it would miss-a-beat or mis-fire every so 5 seconds or so. When I would rev it up, it seamed like it would lose power after a while when I had it opened up, and then shut off when I reduced throttle.
I figured it just needed to be ran. So I shut it off to take it to the lake. While it was sitting, I noticed that gas started leaking out of the carborator. It was like it was siphoning from the tank. When I unhooked the hose, there was a lot of pressure behind it. Is there a air release valve on those older tanks?
I also noticed that there was some cream colored grease leaking out of a hole (the hole looked like it was supposed to be there) in the lower unit.
Another question... Is there supposed to be a sponge in here? Because there is not.
Is this stuff supposed to be happening? Just wondering if I should go run it, or if I need to work on something else. What do I need to do, to get it on the lake.
Thanks
Thanks
