bigbossman
Thread starter- Joined
- Jul 25, 2008
- 6
I just purchased a 1958 RDE 19C 35 HP Johnson. THe only problem is that the wiring harness was not on the engine. How or do I ? or do I even need this wiring to start the engine with the rope start. I am thinking that the wiring needs to be on in order for the circuit to open and let the engine start and also to stop it right? Along with lighting, and guages right? I really just want to fire this thing up to see how it runs. Looks like it was running not long ago so maybe it will be OK??? All help or advice is greatly appreciated with this new adventure I am on. Thanks to all in advance who reply. OK update, tried hooking the fuel line to engine and barring a couple of leaks, fuel did reach the bowl. Removed front cover to ensure there were no mouse nests in the carb, and tried unsuccessfully to pull start the engine. Not sure if it is a fuel or spark problem but would like to hook up the starter and use that vs. pulling my arm out of it socket!! Controls feel kind of stiff but that can be fixed easily enough just want to hear this thing run!!!
