1958 50 hp Chrysler missing when running
tntpoof
Hello I need some help .. I have a 1958 50 hp chrysler that runs rough. Ok this is what I know someone has cut the spark plug wires and put a new section on- The motor sounds like it is missing. idles fine hit the gas and it stalls the catches up but there sounds like a mis..someone also have used automotive wire lugs on all of the terminal block posts..carbs are clean fuel filter is clean.. there is a timing advance rod that might be the issue.. can some one help is it the stator the coils ? I am lost
