goblerblaster
Thread starter- Joined
- Dec 26, 2011
- 180
I have been restoring a 1958 Fisherman 5.5 and now am putting it back together. Had to pull the powerhead to replace the impeller and have a question regarding the TOP of the drive shaft that goes into the power head---- there is a brass washer that is the first thing that goes on top of the driveshaft, then a spring, then a black rubber thing about an inch long, then an o-ring, then a metal washer, then a gasket. SO, the brass washer that goes on the shaft first is flat on one side and concave on the other. Which way is it supposed to go on the driveshaft? Flat side down or concave side down? The spring does not fit inside the concave side of the brass washer . Any help appreciated....
