1958 evinrude lark 35 hp 35514 water pump
Honorary Supreme Mariner
Often they stick open when first opened after 15 years.-----Drop in boiling water and observe.----Cool it off and make sure it closes.-----Repeat 10 times.
jarrod pitts
The parts lists for '58 models dont show one but if yours is the same as a '59 model it is part #105 under the cover #102
To test it first check that it is closed
If it is place it in a pan of water a little cooler than its specified opening temperature (143F) then heat it slowly watching carefully.
It should just start to open at 143F and open fully if you continue to heat,
It helps to trap a thread by the opening flap and suspend it by the thread so that it will drop off the thread as soon as it starts to open
@racerone ah ok. ty again guys. ill check that out tomorrow.
