TruckerBoi
- Joined
- Mar 23, 2021
- 12
Hi Everyone,
I have a 1958 Johnson 5.5 hp that I pulled out of my shed a year ago. I cleaned the carb and replaced the coils and it ran fine in the barrel. I took it out to the lake and when I try to go full throttle, the motor seems to have no power. With no load, it revs up no problem but with a load, it runs but has low rpms. I adjusted the jets and tried priming it but nothing helped. I opened the gas cap and the motor took off at full throttle but died after about 2 seconds. I can get it to run at half power with a combination of half opening the gas cap and pressurizing the tank but I know it can run better. This is my first pressure fed motor that I've worked on and I hope someone sees this and can help.
TruckerBoi
TruckerBoi
