PhilfromOhio
Thread starter- Joined
- Feb 7, 2010
- 82
Okay: Ill start my post like so many other I have posted. I'll fill you in with what I have done, and hopefully you can steer me in the right direction. Recently I have rebuilt and old V4S-10 50Hp. By rebuilt I mean, the entire lower unit, oil seals, clutch dog spaghetti seals ect.. Hey.. No leaks. Then I rebuilt the carbs, new float, needle & seat. Polished the slow needles and polished the fast needles, and soaked the entire body in laquer thinner for two days and de-gunked it. Blew it out with the compressor and checked all the ports, No clogs. then I noticed it was running a bit better, 90psi on 1,3 & 2 cylinders and 85psi on #4. Now, number 4 was white oil soaked and hadn't been burnt at all. So,I checked the spark again, and excellent blue spark as I have replaced the points as well. I bought a complete new reed-plate assy and now all four cylinders are firing properly. I have checked the timing marks and it is in proper position. Here's the problem. I have to choke it to stay running, and the timing mark on the pulley is clear on the opposite side when I plug my timing light up? Could I be 180 degrees out? If so, how could that be if I time it with all the marks lined up? HELP!!!
