1958 johnson 7.5 fuel pump conversion/location
HighTrim
Re: 1958 johnson 7.5 fuel pump conversion/location
Your line destinations are right. Let us know how that BS Pump works at WOT, I have done them for others and tested in my tank, but have not actually ran one on a boat yet.
Zeph, I have used alot of the Mikunis for the QDs and up, but have not found a suitable mount for them on the 7.5s and 5.5s. I have seen the zip tie method, but like NWCove, prefer a neater/cleaner look. If anyone has pics of one mounted post it, would love ideas.
HighTrim
Sorry, but cant figure out why you have to run the outlet line from the pump around the powerhead?
nwcove
not 100% sure i have to route it that way, just from eyeballing it , it looks like the line may get kinked if i take the short path to the carb, but i will try that way first. ( my pump is mounted out about 3/8" from the powerhead)
i now have a new issue with a fuel tank i picked up for it!! will start another thread on that tho.
nwcove
if i remember right , the pump is rated to 14 liters/hr, so it should feed enough fuel, but i am curious about how well the pump will be able to lift fuel. i did use 1/8" id ridged chemical feed line for the pulse, and it is the same as the id for the pump nipples and the brass fitting, hope that does what i think it will do, and create a snappier pulse than a larger id line.
HighTrim
Ive always been ok with the lower loop, as long as I mount on the top bypass cover of course. Looks like your height should be fine to run it direct to the carb.
I only use 3/16" line, as I do a wide variety of motors and I buy it in 100' rolls, but let us know how the 1/8" does with the pump.
Good luck.
nwcove
http://www.youtube.com/watch?v=icOMZ9OvaLA&feature=youtu.be
well here it lives! no carb rebuild yet, or impeller, but it seems to run well and is pumping good water. it does need a shift lever o-ring , which will get replaced when i pull the powerhead for the pump replacement. but the conversion to fuel pump seems to work well in the tank. (fuel was mixed at 10:1 for the first start for the motor in who knows how long.....two smoker!! lol)
Daviet
Man, you gota love the way those old engines run, good job. I hope it gives you many years of service.
kfa4303
Banned
awesome! I LOVE the look of those '58s. Happy vroom-vrooming!
