Re: 1958 Johnson FD-12 Starter Recoil Trouble
Success!
I checked for spark at first and found some, so I thought I was good. But I never tested the plugs themselves, just with a spark tester.
Turns out one of the plugs was shot so I replaced them both. I also rebuilt the carb, not with a kit mind you... but I tore it down and cleaned it with engine tuner and replaced the packing washers as they were absolutely shot and in 3 million pieces making it impossible to set the needlevalves.
So once I got her started she was real lean on the idle setting (coughing a lot). Funny, the manual says to back it out 1 and a quarter turns as a starting point but at that setting she'd hardly run at all... In the end it smoothed out at about 2 and a half turns out, is that weird or normal? The high speed needle recommendation was way off the mark too finally reaching peak operation at about 2 full turns out as opposed to the 3/8th's turn they spoke of in the manual.
Tell me does this sound normal? I'm just so glad she's running, purring like a kitten actually
