stubbstheman88
Thread starter- Joined
- Oct 15, 2008
- 28
I recently just got a 1958 mark 28 that is FLAWLESS. it is in perfect condition with very little paint scraches, and shiny and totaly perfect three blade ss prop, and probable 10 hours or less run time. When i got it i replaced the points, cleaned the carb, and greased the lower unit. I also checked the impeller and it seemed to be fine and in no need of replacement. The first time i took it out it seemed to have trouble getting over about 3k RPM. It couldnt get enough speed to get my 10ft jon boat on plane. I figured it was the carbs so i took it home and did some adjustments. When i took it back it was a little better and seemed to get up to make 4k max. This being a 22hp motor i would at least expect a decent speed with this small of boat but it seemed like i had a 10 horse on the back. I did a few more adjustments of the carb while running and couldnt get any more speed. and another weird thing was that if u throttled down a tad, it seemed to get bit more speed then full throttle. I know that while turning the handle, the carb completly opens and the spark advances all the way but i dont know why its not getting up to speed. im thinking it might be the prop? or mybe something with timing? Any ideas are welcomed.
