1958 QD-19
cc67
The starter housing (376665) on my 58 QD is broke where the starter pulley bolts to it. Is the metal some sort of pot metal? Probably can't be welded. This little motor runs great and looks like a survivor to boot.
Honorary Supreme Mariner
I do not believe they used " pot metal " on outboard motors !!----Cast aluminum is what was used and yes that can be welded
cc67
No Title
Here's a pic of the break. If it's aluminum, I got a guy who can probably weld it.
Worth a try I suppose.-----The issue with welding something like that is the alignment of that part after the welding is done.------If that fails there are lots of those housings available used.
HighTrim
It can be welded, not easy though. MUCH easier to find a replacement. Place a wanted ad at aomci.org in the classifieds, and a local member should be able to help you out.
cc67
Yep, I'm working on that angle. Thanks
