This little motor just keeps stumping me. Fixed the spark issue and tried to fire her up for the first time. The only way it will run is by spraying fuel in the cylinders. Carb is spotless with a full kit in it, including welch plug. It won't run by spraying fuel through the carb with the butterfly wide open. Basicly spraying the reed plate, won't do anything. Spray a little in the cylinder head and she fires right up and sounds smooth for the second it does run. I pulled the reeds out and they are spotless with no cracks. Would crank seals cause this?
