1958 SuperSeaHorse 35Hp Johnson waterpump parts
cgrim1028
after destroying my flywheel during the pull,
I have replaced the flywheel, I got 2 of which 1 was acceptable. and have now started the motor. ran last nite for 10 minutes. this morning I verified
118top cyl/115btm cyl. new coils,points,cond,wires. ran @ idle well. I didn't accelerate.
I had purchased the wrong impellor, so it hadn't been changed. it quit pumping, I shut it down. then I realized, while setting the points I probably rolled the motor 2 directions at which time I rolled the impellor fins. So have now dissasembled lower unit to water pump and find I need the grommets for water pump housing #305095 for the 2 tubes coming into the pump.
What the chance there is a "kit" for this 1958 35 hp johnson available?
I don't know how good I am @ carving rubber.
Any help appreciated, Still trying
Cg
cgrim1028
Re: 1958 SuperSeaHorse 35Hp Johnson waterpump parts
(bump)
still trying to find any waterpump parts info,
thx
cg
