1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
rvcat
Re: 1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
It looks like you are getting to be the expert. I'm waiting on parts for my wizzard. I purchased a carb rebuild kit from discount marine. about $40.00 Good luck with yours, I'm learning from you! thanks, Joe R.
coolbri70
I hope I don't steer you wrong, I,m no expert but i may be by the time i get this running right;) i may need a kit myself, i cleaned it and that seemed to help, had it running for a few minutes, sounded like a peppy motor for 5 1/2hp, my plug wires were hooked up backwards before i believe:confused: i will get it going right eventually:facepalm: i have no manual, going at it blind allmost, i didnt think to observe the location of the pistons when i was setting the points or i would have caught that
coolbri70
had it running again:D this time had it going 20 minutes, i made a video of it but afterwards the file wouldn't play:blue: i tried putting it on my pc and it said it couldn't play as it was corrupt or damaged:grumpy: i was trying to get it to idle and shut off wouldn't restart, then i discovered my video was bad, so i quit for now, nothing ever goes right once i get agravated:mad-new:
coolbri70
One more time: EBSCO Publishing Service Selection Page
LOGIN with USERNAME: Marshall and PASSWORD: public, then click on: Small Engines, Marine/Boat Motors, Oliver and J Series.
thanks, very good info. so far looks like i'm on track. i actually had it running, tried to adjust it but after reading this, i see i need to put it on a boat and stick it in the water to finish adjusting as it needs to be under a load
coolbri70
I hav'nt bought a manual, or rebuild kits, or gaskets, so far just 1 o ring. I told someone it would be bought and running for under $100:rolleyes: Up to $91.24 , thats 75 for the motor, 15 in gas to go get it, the o ring was 1.24, so i only have $8.75 left:facepalm: i got to stop runnin my mouth:)
coolbri70
had some time earlier to mess with the motor, of course my battery on my camera was dead, so it started and i had it idleing and sputtering for 30 minutes or so while i worked on other things. i noticed when i was running it, i had accedentally sprayed fuel all down the side of the wifes mustang:eek: it ran the whole time as i washed her car. had it just above idle, have not yet been able to hold idle. seems like its hunting for timing
coolbri70
i'm having trouble finding the jonboat i want to put this on:facepalm: it has to be under a load to adjust the high speed, so i'm kinda eyeballing the port side View attachment 183774 , i could put in, motor to an out of the way spot upriver then spend the day messing with my motor while i drift along:rolleyes:
coolbri70
coolbri70
got the green on it 021.jpg023.jpg i think it looks ok:D
coolbri70
worked on the fuel lines, i think one was vacuum hose:facepalm: i think it will run better now will try monday maybe 012.jpg014.jpg016.jpg i was 1 hose clamp short will have to find one
ronboonville
It's looking good, been following your thread, keep it up. sounds like you are almost there. Then you can go to the next one.
coolbri70
thanks, i think it was starving for fuel last time i started it, the fuel line to the pump, looked like vacuum hose, i think it was sucking itself flat. im repainting the boat i bought to put it on, and trying to find time is hard when i could have been boating:D but i keep telling myself, when i finish this i can take it to new places, where the big boat wont fit. yep going to explore those 10hp and electric only waterholes:D
ronboonville
What kinda boat did you get to hang that motor on?
coolbri70
012.jpg this 12' aluminum v hull. it was in my price range(cheap) and came with a min kota 40# endura that i can use on electric only waters. i have been prepping for paint. allready made new transom wood for it, want to paint the boat before installing them
ronboonville
Being in the right price range is important. Do you have titles for boat and motor? or going to play dumb country boy like me?
coolbri70
i have a title for the boat, not the outboard, not sure if it had one, the rules here are strange, rowboats don't need registerd then a motor 3 1/2 hp or larger, makes it a motorboat, now it needs registered. in va where i bought my other boat, the va title included a description of the motor, when retitled in wv they ask about the motor on the application but there is nothing on my new title in relation to to motor, i think they ask as to find out if its more than 3 1/2 hp. i dont know how they keep it straight:facepalm:
coolbri70
so i spent $3.50 on fuel line and $4 on paint, so if i need anything else more than $1.25, i hope i can find it in the garage
Willyclay
You have us all hooked on this thread. What happens if you hit $100.00?
