1959 10 hp.. fuel pump?
stingertrey
I read on a site that said the 10 hp johnson was made with fuel pumps starting in 1959 but the sentence was followed with "I believe".. can anyone confirm this for me? exactly what year did they start putting the fuel pump on the sea horse
F_R
Honorary Supreme Mariner
Re: 1959 10 hp.. fuel pump?
The 10hp got the fuel pump in 1960. The 50hp and some 35hps had it in 1958.
However, it seems to be a little known or forgotten fact that a fuel pump kit was offered as an accessory on 10hp-up. It was needed to run on boats with built-in tanks.
jonesg
I have a 1959 Johnson 10hp, QD-20 I think.
It has a pressure feed for the 2 line tank, you can convert it to pump if you want, I got a pressure tank off ebay, its a good system as designed if you have the right tank. Neat little engine.!
stingertrey
Lookin into buying one.. He doesnt know the model number or year.. all he says is that its a fiberglass all white cowl that says johnson seahorse 10 on it.. so i konw its from these early 60 years.. but I dont wanna get into the pressure tank mess bc there expensive.. and how much is the fuel pump kit you talk about F R? and does it bolt right up to the earlier models as a conversion? thanks in advance.
Elbo
50/50 Roll the dice!
F_R
Just for the record, the conversion kit back in '59 was part number 377385. Of course it was obsoleted over 40 years ago.
wbeaton
It'll cost about the same to convert it to a fuel pump as it will to buy a pressure tank. That doesn' include the cost of a new single line tank and hose.
stingertrey
I already got a normal tank and hose.. but thanks everyone think im just gonna go get it asap
