mthuirer
Thread starter- Joined
- Jun 24, 2010
- 113
I'm stuck. I have searched the forum and not seeing what I am experiencing or typing it wrong. I have a 1959 Evinrude Lark. I have rebuilt the carb. replaced the Coils, points, everything underneath flywheel. made sure my gap. .020.. What I am finding is the motor runs great at Idle. Starts up nicely with choke on. then once warmed up idles fine. When I increase speed on the lake I am good at half throttle. If I attempt to go to 3/4 throttle the boat starts lunging or you can say stalling then going stalling and going. I thought at first.. Air leak in fuel system some where since I just bought a new fuel tank and fuel line to the motor. I don't see it.. I placed the old tank and line on and it does the same thing. If this helps I noticed that slow speed cruising it runs great for about 10 minutes and then it starts running rough. If I pick up the throttle and run half throttle it seems to clear up the problem. is this the carb? do I need to sit down and rebuild again. Possible I did something wrong on adjustments on the carb or does it sound like another problem I am overlooking such as float? ect. The Filter looks good.. any opinions greatly appreciated. Thank you.
