1959 Evinrude 5.5 hp lower unit removal
mattkimk
Hello Can anybody tell me how to disconnect the shifting linkage to remove my lower unit on a 1959 5.5 hp evinrude. I am going to get a service manual but I kinda wanted to get started and replace my impeller. Any help is appreciated. I have done these before but this moter is different and I am not sure if I need to remove the power head or not.
Thanks
samo_ott
Re: 1959 Evinrude 5.5 hp lower unit removal
I have a '59 5.5hp. Although most of the parts are sitting in a box! You need to remove the powerhead to get to the linkage which is below it. There is no other way. The powerhead removal is not that hard. 5 or 6 screws from the bottom. It's a good ideas to replace the base hasket when you do as I didn't on my '61 5.5 and it now leaks! They're only a few $$$. Once the powerhead is off, there's just 2 little nuts to remove and then the LU drops off :)
mattkimk
Thanks for the quick reply. I wanted to get this done this weekend so that will help but now I need to buy the base gasket. Thanks for your advice
55'Fleetwin7.5
Where are these 5 or 6 nuts located? Around the bottom perimeter where the shaft attaches to the motor assembly?
F_R
Honorary Supreme Mariner
They are actually screws and come up from below, securing the powerhead to the midsection. Actually, as I remember there are 7 of them, but I could be off.
Please, don't ignore the lower main bearing carbon seal assembly which you will be taking apart. Put in a new 303355 gasket and 303347 oring. These parts are vital for keeping water out of the crankcase.
samo_ott
Good advice FR, the seal is on the top of the driveshaft and looks harmless but is very important.
mattkimk
Well then can I ask you guys another question? I have a 1956 5.5 Johnson that I need to change the impellor on also. Is this going to be the same deal?
Thanks
Matt
