RogersJetboat454
- Joined
- Jul 9, 2010
- 2,964
Re: 1959 Evinrude Lark - Starting Problems!!
Any hardware store should carry grade 8 bolts. You can use this chart to see the difference in markings between grades 2, 5, and 8; Bolt Depot - Bolt Grade Markings and Strength Chart
You could probably honestly get away with using grade 5 bolts (I have many times before), if grade 8 is not available.
Are you sure you had the meter set on the right scales and voltage type? A/C for checking the wall, and D/C for the batteries?
On a somewhat different note, if I need to pull the flywheel to replace coils/points, etc. I have read that I will need "#8 hardened bolts" to prevent the threads stripping. Can anyone tell me where I would find hardened bolts?
Lastly, I tested out my new digital multimeter last night on some batteries and a wall socket and discovered there is something wrong with it. The display started out at 0.11 when I inserted the batteries and slowly kept rising until it now reads 3.21 yet would register no change when the leads were put onto brand new 1.5 V and 9 V batteries!
