1959 gale buccaneer 5hp compression
rick101
Does anyone know what the proper compression reading should be?
tashasdaddy
Re: 1959 gale buccaneer 5hp compression
it is a rope start 50-60 lbs. after 3 pulls.
lindy46
60psi or greater and both cylinders within 10 percent of each other should be adequate for that motor. The higher the better.
rick101
wow ok so mine reads 60 psi on both.
I thought that was low, ok thanks everyone for your help.
