Re: 1959 Glasscat Catamaran Project Underway.
Dave
Hi Dave,
Ingenious use of bracketry, but I see a couple of issues...
The water is an unforgiving mistress, when the pressure of the water is on the engine, and you are trying to turn, I have a feeling that the way you have the brackets set up, it is going to want to twist where it is mounted to the engine...
The other thing is strength...remember that the engine doesn't just turn side to side in the water, it tends to move up, down, get jostled, and vibrated...
That imparts a lot of stress on the steering connections...
I recommend a couple of solutions...
1- Not my favorite idea, becusue it still invovles the use of similar brackets, only much thicker [just look at the size and thickness of the spot where the engine is connected to the steering ram, and see how beefy they are]...plus adding a u-bolt to the bracket where it mounts to the engine, to try and prevent the twisting...think clockwise and counter-clockwise...
2- A much better more solid solution...
If the steering ram/cable can be pulled a bit closer to the attaching point of the engine, connect it directly to the engine and mount the ram on a block of wood on top of where it is now, with a couple of u-bolts...
3- the third possible solution I can think of...if the ram can't be moved... is to have a piece welded up to clamp the two parts together...kind of like this...
Hope this helps...
Be Well,
Gus
