Re: 1959 Johnson 35 HP starter wiring ???
While waiting for an answer, I found a guy in an old posting who had used a spade bit http://forums.iboats.com/showthread.php?t=277190&p=1845833&highlight=spade+bit#post1845833
so I did that and got the seal out and replaced. My biggest problem now seems to be finding the right sticky stuff. I've tried (online) to locate OMC Gasket Sealing Compound, Sealer 1000, OMC Adhesive M, 3M 847, Marpox Sealer 1000, Loctite 30517, Permatex Aviation Gasket Seal and Loctite Aviation Sealant.
Advance Auto Parts has Permatex Aviation Gasket Seal. Nobody else has anything. That includes West Marine and Basspro. Have not yet tried to locate Merc Perfect Seal and I suspect that might be a bit easier to find. So question number one is, will the Permatex Aviation Gasket Seal do the Job?
Question number two relates to the water pump. When I pulled it up, the plate below it had no gasket either above or below but was liberally smeared with what appeared to be silicon seal. I believe I read somewhere on this forum silicon is not a good thing in this application. If that's correct what, if anything should I use? Or should I just reassemble without.? Thanks again.
I just found 3M 847 at Graingers down the street but I think I'd have to order it and wait. Which is better, 847 or the Permatex?
