1959 johnson 50 help
krullbeast
i got it running. it shifts fine and sounds good, but it doesn't pee. the guy i bought it from wouldn't throw in the manual (damnit) and i can't figure out where it is supposed to pee. i had the rabbit ears on with constant flow but it wouldn't circulate water through. i only had it run for 30 seconds at a time just to check the transmission and idle. there's a pretty big hole on the back of the motor where i think it's supposed to pee from, but it looks like it could be an exhaust? anyone know where i should look for the water to come out of? i'll try cleaning the foot intake and see if that helps. any advice is greatly appreciated. thank you iboaters!
Daviet
Re: 1959 johnson 50 help
I don't think you can run that engine on muffs, the water intake is on the lower rear of the cavation plate. You need to run it in a barrel with the water level almost up to the exhaust port on the exhaust housing. The water will come out of the round port in the exhaust housing.
krullbeast
thanks you! i saw that and thought it was missing a plate, but that's where the intake is? huh. makes sense to me. really appreciate that bit of info. i'll give it a try.
