57whitehouse
Thread starter- Joined
- Jun 18, 2007
- 519
Re: 1959? johnson superhorse 50
The puddle it left on the ground was milky oil(thick). It would drip for a day or two after I ran it.
The oil I drained out tonight (from the bottom plug) started out cream color and turned darker(like oil should look). So the oil sitting in the bottom of the gear housing was creamy and the oil that floated to the top was the darker.
Is there a seal between the water pump and the lower housing that could be letting water in the gear lube and gear lube back thru the water pump, and out those holes?
