Re: 1959 Lake N' Sea Restoration
A little more work done. I've been trying to get all the low spots faired in the hull, and I THINK I've got most of them. I'm sure a few more will show up after I've primed it.
I also got the bottom of the deck painted-
Now that the repairs are done on the bottom side, and it's all painted, it's time to flip it back over so I Can finish sanding, do some repairs here and there, and then get it ready for primer. Having the Gantry available for this kind of work makes it TOO easy-
Put some straps somewhere near the center, where the lift will be balanced, and LIFT-
Then, Flip it on the side- When it's balanced, it's super easy to do-
The weight of the deck is still on the strap/hoist...
Flip the strap over, and start lowering-
And, drop it back on to the work stand-
[img]http://www.agott.com/coppermine/albums/userpics/10001/0210Flipped.jpg
Then back to the 'hole' so I can work on it-
That took about 10 minutes total, working alone. SO much easier than any other method I've used. That is one of the best tool investments I've ever made!
Now- I get to start sanding again! Can you hear the excitement in my voice ??
-Andrew
-Andrew
