Perfect painting day today- Mid 70's, NO wind, and slightly overcast... Even the pollen count was extra low- So, it was time.
I got up early, and went out to sand any last imperfections I could find in the hull. It amazes me what you find the next day on a hull that you could have sworn was 'perfect' the night before... The eye is also a liar, learned to trust my sense of touch far more.
Then I wiped it down with a clean rag and a bit of thinner, and waited for the temps to come up just a bit. I like to wait until it's over 70 if I can, just to be sure. Of course, I couldn't sit idle- I did some welding work on the body panels of the truck I'm restoring while I waited.
Just before lunch, I mixed up a 'batch' of urethane paint. I had my sprayer ready to go- it's the first time I've used it, so I knew I'd be playing with the settings a bit. In hindsight, I should have thinned a BIT more- I did about 10-15%, and I got a little more orange peel that I'd have liked, but, Overall, it looks good-
The gloss is GREAT. It should be dry to the touch in about 30 more minutes... Then it'll cure for a while before I cut & buff it... Which should make it shine even more. I like the paint- and had I thinned it a bit more, I think that the spraying would have come out even better. But, I'm certainly no pro when it comes to spraying. I know the only way to get good results is through practice... The rest of us just have to do a lot more wet sanding
One thing that I found to be an issue was trying to get good coverage with a white paint on a white primer- It was REALLY hard to tell where I had been! I had to look at it from an angle. One good thing about this paint versus the other, single part that I had used in the past is that since it isn't reliant on solvent evaporation, you can go a little thicker with the coats and not worry about it bubbling up on you.
It is starting to look more like a boat now
-Andrew
