crashpro
Thread starter- Joined
- Apr 10, 2011
- 40
I just purchased a boat that has a 1960 10hp Johnson motor on it. I've been trying for two days to get it running, with limited success. I have new sparks plugs, new fuel tank, and new fuel. It takes 25-30 pulls to get it to start, and then will only start when the throttle is at the idle position. It won't even fire when it's choked and the tiller handle set at "start" position. If it's not set at idle, it won't even try to start. On the rare occassion that it does start, it will usually only run for about 10 seconds, then coughs and dies. I set the needle valves initially at 1 1/2 turns out and 3/4 turns out as I read on these forums. Once running, I adjust the appropriate needle valves to keep it running, again, as the forums have directed. At one time, I had it running for about 10 minutes and was able to accelerate (only extremely slowly) to full throttle. I adjusted the mid-high speed carb needle, idled back down and it was running like a sewing machine. Then it coughed and died and I was not able to get it to fire again the rest of the evening. I don't have a clue what to do from here.
