1960 big twin 40 timing plate question
nahoo7
So motor broke down on weekend and I couldnt restart it.got it home and tried a few times and it popped once or twice,so I thought maybe timing is off.So I pulled the flywheel and the timing plate was not attached properly, I found 1 screw on the block.my question is, is there only 1 screw holding the advance plate underneath.I only took a photo of the top so I knew how to reconnect coils and condensers and points and cant remember how the underside went back together.any advice appreciated cheers.
Roberthill
Re: 1960 big twin 40 timing plate question
Tried paste ing you a breakdown but couldnt get it to work
Honorary Supreme Mariner
There are 4 screws on the brass collar underneath the magplate.------There are also 4 screws that hold the magplate itself down in position.
nahoo7
Ok maybe I didnt explain it properly it is the piece that moves in and out with the throttle also the plug leads are mounted to it cheers.
F_R
Correct name for it is armature plate. Nevertheless, it mounts as racerone said.
