1960 evinrude 40hp motor running 1/3 power
Dickinson
Hey all, I need some help. I have a 1960 40hp evinrude and when i have it at full throttle it seems like it is only running about 1/3 speed or power. Any thoughts? Thanks for your help!
samo_ott
Re: 1960 evinrude 40hp motor running 1/3 power
Sounds like you're running on one cylinder. Do a spark test with a good tester. Or remove the plug wires one by one when it is running. If running on only 1 cylinder then 1 wire will do nothing and the other will kill the engine.
R.Johnson
49 years old, do a compression test along with the spark.
samo_ott
49 years young!
Dickinson
good compression and motor's running on both cylinders.
R.Johnson
Is the carb going to full open, and ignition plate going to full advance?
dawsonbec
Im Having the same problem with my 1996 48 Johnson. So if u pull off one plug and nothing happens and then u put it back on and then pull the second plug and it dies that means its running on one cylinder?
