FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
This may seem dumb. I am putting gear oil in through the top hole. It is not taking alot. I drained it do i think i am doing it wrong. Bottom screw is in.
Tom - It is best to fill through the bottom drain plug. Be sure to have the top plug removed during this time. Once oil starts flowing out the top hole you know you have it full. You can then put the top plug in and then quickly remove the oil bottle from the bottom and install the plug.
Hi Tom. Yes, you should fill from the bottom up using a small hand pump in order to eliminate any air pockets. You can get a quart of 80-90w hypoid outboard gear oil and a hand pump from any wal-mart. You'll also need to replace the white, nylon crush washers found beneath the DRAIN/VENT screws. Here are some handy links that can walk you through the job.
