evinrude36
- Joined
- Mar 21, 2010
- 36
Re: 1960 Evinrude Lark 2 No Spark
Before I even took the flywheel off I ordered an ignition tune-up kit. Then when I took the flywheel off I found that the coils were bad so I ordered them too. I did not order spark plug wires which I hope is not a mistake because I want to get this thing running asap! They seem to be okay. I did clean out the carb and it was bad but it's clean now but I am definitely going to buy a rebuild kit if I ever get it running. I do have one more question for you guys. When I opened the drain plug on the lower unit no oil came out. When I shift it into forward the propeller does turn so I hope it's not a big deal but what oil should I use in that? I have heard of 80w-90 and type C. Which one is right for this engine? Again, thanks for all the replies. I was not expecting to get so many replies. Usually on the other forums I've been to I've only gotten a few. Thanks for all the help!
