1960 johnson 40 seahorse spark only on the bottom cylinder.
rprs0
Hi all,
I new to this forums I got a 1960 40hp seahorse from craigslist for 80 bucks, I don't think I overpaid since the compression is good 120 across both cylinders, so I read the "waking a sleeping outboard" post i found very helpful, oiled the pistons through spark plug holes, easy to turn by hand, checking spark I only get spark from the top wire, so I guess its time take off the flywheel and inspect magneto right? also the shift seems a little off when its in neutral its in reverse I guess its linkage, any advice would be appreciated, I hoping to put this engine on an 1986 16 capri bayliner that I got, the force 85 thats on it has low compression on center cylinder and don't start. Which engine better I think the seahorse seems better quality, right
boobie
Re: 1960 johnson 40 seahorse spark only on the bottom cylinder.
If you can live with half the hp go for the 40 hp. Pull the flywheel and check out the mag.
lindy46
Make sure the safety switch/cut-out switch is not grounding out. That would cause you to have no spark on the bottom cylinder.
rprs0
Thanks I'll check it this afternoon.
rprs0
Thanks for tips found one of the coils was fried.
1946Zephyr
Very typical for the old OMC twins. A new set of coils and that motor will run out from under you :D:D
Very tough and reliable motors. You'll enjoy it.
smanb098
Hi there
I have the same motor. I popped the flywheel to check coils and condition and gap of the points. I was not observant enough to note the attachment locations of the spring which is attached to the carb linkage and ?????. I think that its some what related to the pull start safety lock mechanism which in your picture is laying toward the front of your motor.
any help or hint that you can lend is appreciated.
Thanks Seb
1946Zephyr
Hijacking a thread is a no no. You may want to start your own thread. Welcome to iboats ;)
rprs0
IMAG0324.jpg Heres a picture of spring location if you still need it, look for the brass washer with a hole in it.
