1960 Johnson RDS-22
b717doc
Sharing my new found motivation for my old boat, that's basically been sitting beside the house for the last few years. I get the itch to go fishing every year about this time, and had contemplated just taking the old Johnson outboard off of the boat, and installing a good trolling motor and be done with it, as the motor had basically kicked my butt out on the open waters more than once. But thanks to googling the engine serial number, I found the Iboats site, which has re-ignited my interest in the old engine. AMAZINGLY simple to work on, now that I have a manual (Thanks Bill), I got the flywheel off, and there, hidden, was ALL of my problems. the right side coil has a large "jaws" sharkbite looking chunk out of it, the bracket that turns the armature was completely separated and dangling (2 countersunk screws fell out, found at Home Depot), brass linkage that actually connects to bracket bent from years of "forcing" accelerator knob forward. Entire armature restricted from hitting stop, due to ignition control wires binding on starter bracket. Went by after work yesterday and bought new coils ($27 a piece), and a "tune-up" kit that has 2 sets of points, and 2 condensers, for another $27. Thread locked the countersunk screws, removed brass arm, placed in vice and re-formed to original shape, re-positioned ignition control wires to allow armature to fully travel smoothly to stop, Everything working sweet now, can't wait to put her in the water on Monday...will be 55 degrees here in the ATL, and Allatoona looks to be about 3/4 full. I'll either be cussin' or cruisin, but will be ready for Lake Weiss, where the real fishing is....
tashasdaddy
Re: 1960 Johnson RDS-22
STOP!!! do the water pump before using, no need to burn it up now.
b717doc
Okay, will check water pump, but I do remember replacing that impeller year before last...will definitely check it....
tashasdaddy
they are cheap insurance. being out of the water they dry out, and become brittle.
b717doc
Well, not going as smooth as I thought it would, when putting everything back together, like re-installing the armature plate, the darn thing locks up and won't rotate, like the screw is too long. Tried a shorter screw, no help, don't add up. Went ahead and installed new contact points and coils, temporarily installed flywheel to check compression, got 90 psi on both cylinders..not bad I think, considering. Apparently lost one of the eccentric contact point screws, adapted and overcame, got tired, had to quit. Was trying to get done with it so I can take the cylinder head off that darn Triumph tomorrow to fix an oil leak on it...running out of time. My weekends are too short....
