Arawak
- Joined
- Aug 27, 2010
- 486
I'm having some problems shifting my 4 cyl 1960 Merc 400. When I got it last year I dropped the lower unit to replace the impeller (see: Thread: 1960/61 Merc 400 shifting problem (no reverse locking cam?) ). Last week I got it all hooked up again, started her up, but when I put it into reverse it went forward.
Removed the shift cable and shifted it manually into forward to take it for a test run up the lake. Could not get it more than about 1/3 throttle.
Now, I'm not sure if I have the cables connected correctly, but when I put the controls into forward, it pulls the shift lever on the motor forward (towards the bow), and when I put it in reverse it pushes the lever backwards.
When the shift lever on the motor is forward, putting in gear, the prop spins in the forward direction, but I am limited to about 1/3 of the full movement of the throttle lever. When the shift lever is aft, the prop is in reverse gear, but I have full range of throttle.
This sounds to me like I have the gears reversed on the lower unit when I put it back on. Anyone know on these motors which way the shift lever moves to be in the forward and reverse gears?
