1960 sportwin 10 power head removal
cadet917
i have all the bolts un-done and the power head has lifted about 8mm and now its stuck. is there something in the lower unit that needs to be disconnected?
its a model 10020.
F_R
Honorary Supreme Mariner
Re: 1960 sportwin 10 power head removal
its a model 10020.
No. Your drive shaft splines might be rusted in the crankshaft. In a worst case scenario, disconnect the shift rod and remove the lower unit (force it off). That will force the water pump pin through the top of the water pump housing. Then you can remove the powerhead and deal with the stuck shaft out in the open. When you get it all cleaned up, be sure you have a new o-ring in the drive shaft groove and grease the splines. If the last guy had done that, you wouldn't be having this trouble. Also, make sure all the proper seals and stuff are on top of the water pump. They keep exhaust and water from going up to get at the splines.
cadet917
i got it off with some pulling and the long stainless rod came with the powerhead... should i remove it or just leave it? what do u recommend i replace now that its all apart.
F_R
The long stainless rod is the drive shaft. You will never get a better chance to remove it than you have right now. Left alone, the splines eventually will rust away and it will come out easy. But it won't drive either. Get it out, clean out the rust, and make sure the o-ring is there when you put it together.
cadet917
i noticed a small half moon type key on the lower unit end of the drive shaft. what is this?
tx1961whaler
It's for the water pump impeller. The key allows the impeller to rotate with the drive shaft.
cadet917
i took this all apart so i could get at the head. i cut the head with a die-grinder about an 1/8 inch from the block and cut through all the broken bolts. It still wouldn't budge so i started going at it with a hammer to break the head of piece by piece and the block cracked so its goin on ebay piece by piece. really sucks since it was running and 1 little thing ends up ruining it.
F_R
Oh, you're the guy with all the busted head bolts. Yep, really sucks. The half moon key is to drive the pinion gear at the bottom end.
