1960's 13' MFG carefree Rebuild (complete noob, i know nothing about this!)
Woodonglass
Re: 1960's 13' MFG carefree Rebuild (complete noob, i know nothing about this!)
I'd just use PB to fill the bubble divots.
BoatgoatmfgVT
Hey Woodonglass, i just got primer for my boat, i got the Majic tractor, truck &Implement primer. I wasnt sure if i was supposed to get that, or the Majic Sandable primer. Will this stuff work? Thanks
Woodonglass
Did you get the Grey Stuff?
BoatgoatmfgVT
Can i also use the Sandable primer?
Woodonglass
You mean the Spray Can stuff
BoatgoatmfgVT
no, it came in quart and gallon containers. The stuff i got is called Tractor, Truck & Implement(exterior oil base enamel). I was not sure if i was supposed to get this one, or the one that says it is sandable. I have the opportunity to go back to tractor supply, so i am wondering if i should return this one and get the sandable stuff. Thanks
Woodonglass
This is what you should use.
[h=1]Majic Paints 8-0986-1 Majic Tractor and Implement Enamel, Gallon - Gray Primer[/h]
BoatgoatmfgVT
Alright, yet that is the stuff i got. Except i got it in 1 quart containers, do you think 2 quarts will be enough for my boat?
Woodonglass
Are you rolling or spraying?
BoatgoatmfgVT
I'm going to be doing your Roll and roll technique
Woodonglass
If you thin the Primer with 1/2 cup of Mineral Spirits Per quart then you should have enuf. Make sure and use the Ultra Dense/Fine rollers.
BoatgoatmfgVT
Thank you, this is golden information!
BoatgoatmfgVT
Do i use the catalyst hardener with the primer?
Woodonglass
No hardener in the Primer just in the final Color Coats.
BoatgoatmfgVT
I just thought of how i can redo that steering wheel with fiberglass vacuum bagging, maybe i could wrap 2 pieces of 1inch csm fiberglass tape around the steering wheel at opposite 45 degree angles then put it in a vacumm bag. Do you guys know anything about vacumm bag laminating?
jbcurt00
Nope sorry, but have you looked at POR15's steering wheel repair kit?
BoatgoatmfgVT
Havent gotten squat diddly done in over a week! The wax additive just arrived so i decided to do some fiberglassing, i put 2 more layers of csm over the keel, and then ground a taper on the bow end and built it back up with a piece of csm, 1708 and another piece of csm. Will probobly add more csm to the bow end. . On another note, i am replacing all the gaskets and seals on the lower unit of my motor, does anyone know how to remove these seals? Got that last one out with a romex staple, a hammer and a socket, redneck'd it! I also started a thread on the motor, just thought i might get even more results if i posted it on my boat build thread. Thanks for lookin guys!
BoatgoatmfgVT
So i ordered a HVLP paint gun and it will be here in 2 days! Can't wait to paint this boat, its been a long long run of work on it. I have a question regarding fairing compound, i made a fairing compound with microspheres and resin, i also added surfacing wax to it. Was this a No no? Is it okay to add wax to thickened resin? Despite the wax, it is still taking a while to cure( its pretty humid out), so hopefully that will cure so i can sand it with a long board sander.
