Purchased a 1960's Flying Scott 60 hp motor this week. Looking to get her running. Did compression check on her She has the following:
Cylinder 1 (Top) 100psi
Cylinder 2 (Middle) 105psi
Cylinder 3 (Bottom) 105psi
I don't know what they should be, but they are in range of each other +-5psi.
I tested for spark and I do not have any spark on Cyl #1, Cyl #2, or Cyl #3. Not sure what this means (I will take advice from anyone out there). I will start diagnosing this system in the morning. This system has an alternator (stator), distributor. I am not familiar with these systems I have only ever worked on the magneto type before, so help would be greatly appreciated. Especially where to start.
Also does anyone know: The starter is fried (working on locating a new one), so I am hand cranking. Do I have to have the system hooked to a 12 volt battery and the ignition on, to pull start this motor? I am wondering if the reason there isn't any spark is because of a safety switch or something.
Thanks for your help.
p.s. Previous owner did have this motor running this year (he says
