sailing1258
Thread starter- Joined
- Apr 15, 2009
- 10
I had this motor professionally evaluated, and was told it needed a new plate, new points, new coils, and had a loose rod. Basically, I was told it wasn't worth the money to have it repaired professionally. Can the parts be obtained (O.E.M. or aftermarket) for an older Evinrude motor at reasonable prices? I was told the compression was good, but not great. (55 lbs both cylinders) Is a rebuild necessary? Are there companies that make aftermarket parts? The repairman told me a new plate for this particular motor would run $300.00. Can you find good used parts out there? If so, where?
