1961 evinrude 10 hp sportwin
Motor guy
Hello i have a 1961 evinrude 10 hp sportwin. i need a owners manual and some info onit. and i need a gear shift lever that goes on the side of the motor. model # is (10022)any info is appresciated. thanks,Cade
samo_ott
Re: 1961 evinrude 10 hp sportwin
I have the parts manual for it if you want to PM me with your email address and request I'll send it to you.
1946Zephyr
Do you need parts for that bugger? I have a 61 model here and if there is anything you need, let me know.:cool:
Motor guy
Thank you samo_ott and 1946Zephyr. The only thing wrong with it now is the gear shift handle on the side of the motor is broke. The motor runs great though. It wheighs about 50-60 pounds. Will it be able to go on a 10 ft boat?
BigB9000
mine is going on my 8' boat
Motor guy
I bet that little 8 ft would go fast with that 10 hp on it.
gonecuddy
Hey Motor guy, We just bought an older 22' cuddy and the owner threw in this 1961 10hp Sportwin. I don't even know what the 3 control knobs on the front do. Can you assist?
Motor guy
im so sorry for not getting back to you but the center and the right knobs are high and low gust set the arrow facing down on both if u rum 50:1 and the far left one is the choke. sorry for the lateness i haven been on here in a while
Motor guy
does any one know the value of a good running 1961 evinrude 10 hp sportwin?
1946Zephyr
This thread is just a bit old. You probably should have started a new one. The mods here may take you to the woodshed for this one. :D:D
tx1961whaler
But doesn't he fall under "The OP can drag up his own thread" rule? ;)
