Hydrodyner
- Joined
- Jun 11, 2017
- 12
I was able to drop the lower unit on my Starflite III. After draining the milky gear oil I rigged up a pressure test unit. At very low psi I could hear hissing so I sprayed soapy water around the lower unit. I found a leak coming from the hole with a brass bushing that the shift rod passes through. Any advice sealing this leak would be appreciated.
