Hey guys-
Fixing up an old 1961 40HP Johnson sitting on a 64' Glasspar Lido and have gotten it running pretty well. What I've done so far:
Rebuilt carb
Rebuilt fuel pump
Replaced all fuel hoses
Replaced impeller
Replaced primer bulb and hoses
In the process of putting the lower unit back on- I broke the lower unit(gearcase?) housing because the metal is all pitted and weakened and didn't hold up too well to a rubber mallet. I've found a replacement lower unit housing and was hoping you guys could give me any tips or ideas on swapping the gears in the lower gearcase.
Is there anything in there that I should replace while I have it open? The prop seemed to be doing good in the water before I broke the housing.
I have a manual for the outboard, but it's not great and doesn't cover this area in depth. Does anyone know where I can find a good book/diagram for this outboard? Thanks guys-
Rebuilt carb
Rebuilt fuel pump
Replaced impeller
