twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
Just resurrected a 1961 Scotty 3.6. that has no corrosion and apparently very little use. Got the piston unstuck, cleaned the carb, and transplanted an OMC coil and got her fired up. Only problem is that something is wrong with the cooling. She's not putting any water out the exhaust/discharge hole at the top of the lower unit. I checked the passages of the head when I had it off and the pipe through the lower unit and everything is clear. The impeller is the original round type that works of a concentric. The motor was not used very much and the impeller is still fairly pliable and though I will replace it I have a doubt that it's the problem. Any suggestions are greatly appreciated. thanks
