1962 Chris Craft Holiday 20’ bucket list resto
sphelps
Yes , it just has a little surface rust in a spot or two . The inside looks pretty clean really ..
I do want to paint it with some sort of good paint for galvanized metal though .. Any suggestions?
sphelps
If your interested I made an intro video. I’ll win no Oscars for my performance.. And I mistakenly called it a 61 instead of a 62 year .
Almost senior moment there .. LOL !
sphelps
So what’s the trick to getting the exhaust rubber pipe loose ? LOL !
The grab and growl method ?
froggy1150
Hose- dull screwdriver and channel locks . Gently work screwdriver in and around while also gently working hose back and forth with channel locks. Eventually ot will break free as you get deeper.
Dash- looks worse than mine did and I had more stuff
sphelps
Hunny do project finally complete ..
Built an extension to my house porch and screened it in for the Admirals hot tub area .. The sand knats are back in full force ..
sphelps
Also got the permanent lights hooked up in the garage . Installed a sub panel . Still need to add some receptacle's . And contemplating an AC unit .
sphelps
So do you think if I add the AC unit it’s gunna start raining on me if I don’t insulate the building ?
todhunter
Canoeist
Get some quotes on having it spray foamed...I was pleasantly surprised at the price. I had my garage foamed and added the 24,000 BTU mini-split and it was life changing. Power bill is a little higher in the summer when I'm busting out a lot of projects, but it's so worth it.
sphelps
2” of closed cell would probably run around 3600 bucks or so . R- value around 15 .. That’s not doing the 2 ends of the building..
