1962 Evinrude 5.5 fisherman bogs stalls when I put the hood on.
BlackoutBill21
So, with hood off it will run full speed full throttle no issues… when I put the hood on, it revs up then I lose power and rpm’s… it won’t stall but just stays starving for fuel or air.
Any thoughts?
F_R
Honorary Supreme Mariner
Running it on a boat or in a barrel? If in a barrel, get it out of there and onto a boat where it was designed to run. Or stick your head down in that barrel and take a snort of that smoke and you will realize the problem.
BlackoutBill21
It ran good in the barrel. The water is where I ran into a problem
jitterbug127
99% chance its an exhaust leak. You'll either want to replace the gasket, run motor with cowling off or drill holes in cowling to allow more air to come in (drilling holes not my choice).
Checked slip clutch below the water pump.-----Lower unit binding ?
Crosbyman
pull the phead change impeller anyway if needed ...check the slip clutch (just weld it at
6'' 11/16 inch and use brass drive pins)
check for heavy carbon build up in the exhaust section change the base gasket (carefull they all look alike but differ by year )
... no reason for the fumes to enter the cowl.
if choking is the problem seems you should see/smell heavy exhaust when you pop the cowl off... do you ??
BlackoutBill21
When it first starts running. After about a minute she seems to lean out and way less smoke
BlackoutBill21
Thanks for all the reply’s. I’m gunna pop the power head and have a look see
Crosbyman
good decision . here isa good video on it...simple process
be very carefull with the top carbon seal..they are very brittle
check GC for water intrusion... some just refill mid-season if not at ease witha GC reseal job
to service oldies the Johnson red book.. or white covers everything you need
