1962 Evinrude 5.5hp water pump
Old56
Hey thanks to all of you I finally got the old gal running but noticed no water was comming out of the hole half way up the impeller looked ok when I had lower unit off could there be another issue like faulty thermostat I only ran the motor for about 30 seconds for fear of damaging it any help in this area would be appreciated.
Once again thanks to all who responded
flyingscott
Do you have it in a tank with the water level about 6" above the impeller?
Old56
I had it in tank with the water level 3 inches above what I believe is the water intake plate so I guess I didn't have the water high enough??
