1962 evinrude fastwinn 18 hp.Which fuel line goes to the pump?The one close to the block or the ot
jimmbo
The Fitting that goes to the Inside of the Filter/Strainer, goes the Pump. The other One will go to the Fuel Connector.
Of Course OMC may have put the Filter between the Pump and the Carburetor... In which case the Pump is connected to the Hose Connector, and the Fuel Pump would be connected to the fitting that goes to the outside of the Strainer/Filter, and the fitting that goes to the Center of the Filter would go to the Carb
Mc Tool
Yeah , plumb it so any water or dirt is outside the filter element ,in the glass bowl....where you can see it .......thats why its glass 🙂
any arrows on the filter?---I might look at one here once daylight arrives.
Well----I looked at 2 of these filter housings.----2 of many that I have.----Clearly there are arrows.-----The one furthest from block shows IN---And one closest to the block shows OUT ----So best to look at yours more closely.
